KNara.2
Communication from screen to backend
  • July 5, 2023
  • 1857 views
I'm trying to send an event when a button is clicked.
I have added an interaction in Touchgfx designer to call a virtual function when the button is clicked.
In Screen1view.cpp I'm overwriting the virtual function
void SendDataOnButtonClicked()
presenter->SetMode();
in presenter.cpp
void Screen1Presenter::SetMode()
model->SendEvent();
In Model.cpp
void Model::SendEvent()
Send data to backend.
Is this the correct way of sending data to backend when button is clicked ?
Right now I'm stuck at view.cpp.
I dont know how to call presenter  from view.
Codes that I tried.
Method 1:
Screen1ViewBase::presenter->SetMode();
Method 2:
Method 2:
Both these codes are throwing compiler errors.
Can somebody please help and let me know the right way of accessing the function in presenter?
Best answer by JTP1
Hello. Method 2 is correct. There must some simple problem at hpp file maybe ... This 'void SendDataOnButtonClicked()' must be of course 'void Screen1View::SendDataOnButtonClicked()'.
What is the exact error ?
Here you can get simple example of MVP communication in both directions:
https://community.st.com/t5/stm32-mcu-products/toggle-button-off-after-a-specific-interval/m-p/569065#M217071
JTP1Best answer
Graduate II
July 5, 2023
KNara.2
KNara.2Author
Thank you so much @JTP1 .
Your solution helped.
