KMitt
Application template for stm32 not loading in touchgfx, showing error...
  • June 1, 2019
  • 8 replies
  • 3278 views
Not able to load any templates except the windows template.
Martin KJELDSEN
Principal III
June 3, 2019
Hi @KMitt​,
Can you please attach your log file?
/Martin
KMitt
KMittAuthor
Thanks for the reply...there was no log file generated because it can't load the template. It finally worked when I changed the directory location.
Can you put links for tutorials on modifying the code for adding different buttons (especially sliders).
Also what type of compiler will be good if I don't have visual studio
KMitt
KMittAuthor
Hello
Can you look into this. The slider button is causing problems. I think the issue is from software side
please check
Martin KJELDSEN
Principal III
August 5, 2019
You have no background.
