Question on counter initial value for AES CTR on STM32WB
PADAM.1
Hello
In chapter 22.4.9 of RM0434 Rev6 is stated:
Counter: a 32-bit big-endian integer that is incremented each time a block
processing is completed. The initial value of the counter must be set to 1.
Why can be the initial value of the counter not be set to 0 (as far as I know it is possible in standard)? Is this a bug?
Best regards
Paul
Nicolas ANQUET
Hello Paul,
When initializing the AES for the first block what you are proposing makes sense. However, by doing as recommended in the RM0434, application can start AES-CTR computation at any block number (see principle of suspend-resume sequence).
Best regards,
Nicolas
