Which API use for RTOS?
Adriano Melis
Posted on November 17, 2016 at 12:57
The STM32cubeMX code generator labels as FreeRTOS the RTOS functionalities, but the code generated looks compliant to the CMSIS-RTOS API.
The directory Middlewares\Third_Party\FreeRTOS\Source contains the sources for FreeRTOS and what looks to be a cmsis-rtos wrapper to freertos.
I have some questions:
- is it possible to generate code for freertos and use only the freertos API?
- alternatively, where is the documentation to this version of cmsis-rtos?
#!freertos #!cubemx-!code-generation
Walid FTITI_O
Senior II
Posted on November 17, 2016 at 16:33
Hi adriano_melis,
As an answer to all your questions , refer to the User manual
http://www.masters.com.pl/szkolenia/zasob/plik/720267774rtos.pdf
''Developing Applications on STM32Cube with RTOS'', where CMSIS-RTOS and RTOS application are documented.
For RTOS configuration on STM32CubeMX tools , you would refer to the part ''4.12.6 FreeRTOS middleware configuration view'' in the User manual
http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM00104712.pdf/files/DM00104712.pdf/jcr:content/translations/en.DM00104712.pdf
'' STM32CubeMX for STM32 configurationand initialization C code generation ''
-Hannibal-
