Wen Song Yuan
Visitor II
July 13, 2018
where can I find the tm32cube-fw-l4-v1120.zip
  • July 13, 2018
  • 1271 views
Posted on July 13, 2018 at 05:15
where can I find the tm32cube-fw-l4-v1120.zip ? Because the internet speed is too slow to update the stm32cubeMX automatically.
    Best answer by Szymon PANECKI
    Posted on July 13, 2018 at 09:26
    Below please find a link, where you can download the package manually:
    https://www.st.com/en/embedded-software/stm32cubel4.html
    Szymon
    Szymon PANECKI
    Szymon PANECKIBest answer
    Senior III
    July 13, 2018
    Szymon
    Tesla DeLorean
    Guru
    July 13, 2018
    Posted on July 13, 2018 at 12:48
    https://drive.google.com/open?id=12JUPZc22Q6Y6M9utjc2laC5VIMBHZCZK
    If you have poor/intermittent internet service I can probably create a torrent.
    Watch also that you have enough hard drive space, the files are quite large, and unpack to 2x size, so going to want several GB free. CubeMX isn't always specific about the mode of failure, I've seen it report a download failure when drive space was tight.
    If you run Win7 there is a bug where Microsoft packs the hard drive with log files, I had issue where those consume several hundred GB
