We want to light up an LED when a hard fault occurs.
  • October 15, 2024
  • 832 views
Please tell me in which handler I should put the GPIO processing.
Also, We would like to turn on the LEDs for faults other than Hard fault, is that possible?
Best answer by Andrew Neil
Good idea!
In the Hard Fault Handler!
On debugging Cortex-M Hard Faults - in general, and STM32 specifically:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/tac-p/708193/highlight/true#M51
Of course - do it in the handlers for those faults
Andrew Neil
Andrew NeilBest answer
Good idea!
Thank you for your prompt reply. It was helpful.
