Using TIM3 in STM32H753 to trigger BDMA
‎2021-10-19 2:36 AM
I'm trying to generate a serial data pattern in STM32H753 for WS2812B LED chip. I did it before with STM32F2, as the TIM, GPIO & DMA2 are within the same data bus matrix, i'm able to use TIM module events as a trigger event for DMA, and start moving data from RAM to GPIO.
In STM32H753, TIM modules are inside D2 domain, GPIOs are within D3 domain, if i gonna move data to GPIOs, data must be in SRAM4 and handled by BDMA.
Is it possible to use TIM module in D2 domain to trigger BDMA, that i can move data from SRAM4 to GPIO for generating the serial data pattern?
Many thanks
- Labels:
DMA
STM32H7 series
TIM
‎2021-10-20 12:55 AM
Thanks for the reply.
I think i misunderstood the architecture, i could use DMA1/2 to access GPIO in domain D3. I thought DMA1/2 in D2 domain couldn't access peripherals in D3 domain.
Its now working and i could use TIM8 to trigger DMA & move data to GPIOE.
‎2021-10-19 2:48 AM
Have you tried it already? If it does not work ensure that HAL generated BDMA initialization is before TIM/GPIO peripheral initialization.
