terence-b
Using NRST for system reset through hardware
  • March 30, 2013
  • 3 replies
  • 1035 views
Posted on March 30, 2013 at 19:25
Hi
I would like to apply an automatic system reset in case a particular condition in my system is met. I already know how to apply a system reset through software. Now I want also to do it via hardware. If If I pull pin NRST high, will it have the same effect as when I press push button B2?
Thanks,
Terence
    Tesla DeLorean
    Guru
    March 30, 2013
    Posted on March 30, 2013 at 22:05
    No, you'd want a pull up to hold in the normally high state, and then drive it LOW using an OD driver to reset it. You should not drive this pin high with a PP driver.
    terence-b
    terence-bAuthor
    Posted on March 31, 2013 at 23:14
    Thanks for your reply; but can you please explain more clearly, as I cannot understand the terms OD and PP driver.
    Thanks in advance
    Terence
    Tesla DeLorean
    Guru
    April 1, 2013
