USB data FIFO map: question of newbie
Posted on April 10, 2013 at 19:56
Hi all,
As I said previously, I am learning USB and reading and reading again the USB spec. I want to understand the USB dta FIFO. In fact in table ''Data FIFO access register map'', there is an address range. For example for EP0; the range is ''0x1000–0x1FFC
'' My question is: as it is a FIFO should be a set at a single address for read/write (as an example ''0x1000'') and not a range? Thanks
