TGFX, How to manage common screens for different projects?
zzzzz
We have two similar projects that have many files are in common. Many screens are also used in common. Currently, there have two TGFX designer projects to make GUI code for them. We need to figure out an easy way to manage these common files, directly use the generated code, not change the directory or the code. So,
Is there a way to only generate code for part of the screens(selected screens)?
Or is there any way to modify the file generating directory, keep two GUI projects, common screens are generated in a common folder?
Or any other ideas?
Thanks in advance.
0 REPLIES 0
