moran
STM32L152 - can't woke from stop mode
  • June 23, 2015
  • 750 views
Posted on June 23, 2015 at 08:09
Hi everyone,
I'm trying to write code that  :
1) Enter STOP mode every falling of specific  EXTi pin.
2) Wake up every rising of this pin.
This is my code :
void
EnterStopMode(void)
// ASSERT(false); // Code is not written yet
  PWR_VoltageScalingConfig(PWR_VoltageScaling_Range3);
  PWR_UltraLowPowerCmd(ENABLE);
  PWR_EnterSTOPMode(PWR_Regulator_LowPower, PWR_STOPEntry_WFI);
/////////Interrupt routine :
void EXTI4_IRQHandler(void)
    /// Falling ///
    if(!(GPIOA->IDR & GPIO_Pin_4))
         EnterStopMode();
    /// Rising ///
    if(GPIOA->IDR & GPIO_Pin_4)
           ///Test point/// ---> debug probe
       l_index^=1;
       GPIO_WriteBit(GPIOD,GPIO_Pin_10, (BitAction)l_index);
    // Clear the  EXTI line 4 pending bit
     EXTI_ClearITPendingBit(EXTI_Line4);
The device is entring stop mode ( I can see it using breakpoints ) , but it doesn't wake.
It stuck there and i can't see any EXTi occur.
Please advice.
    tm3341
    Posted on June 23, 2015 at 13:55
    Try to first clear EXTI interrupt pending bit and try again.
    moran
    moranAuthor
    Posted on June 24, 2015 at 08:42
    You right ....but still it doesn't help.
    Below is my new IRQh :
        /// Falling ///
           l_index^=1;
           EnterStopMode();
        /// Rising ///
           l_index^=1;
    I'm probe out to scope the debug pin ...so i can see if it toggle --> wake up
