STM32H755_CM7 and STM32H755_CM7 svd files v1.9 missing MPU and NVIC peripherals
  • March 25, 2024
  • 3 replies
  • 1606 views
I'm in the process of generating the Rust PAC for the STM32H755 using the svd files. I've downloaded the latest svd file v1.9 from here stm32h7-svd.zip I noticed that the file is incomplete as the MPU and NVIC peripherals are missing for both the CM7 and the CM4 file. Where can I download a corrected set of svd files?
STTwo-32
Hello @taunusflieger
I will escalate this issue to tha concerned team to correct it on the next releases.
Thank you for reporting.
Best Regards.
STTwo-32
Thanks - when can we expect an updated version? This is currently blocking us.
STTwo-32
After investigation, The SVD file doesn't contain any of the Cortex Features (including MPU and NVIC). It just integrates the STM32 features and IP (I2C, UART,...).
Best Regards.
STTwo-32
