May 20, 2024 4:27 PM UTC
STM32G491 Pin1 Marking
Hey, i
got this STM32G491MET6
The datasheet does not really help here to identify pin 1, since there are 4 markings to see. Anyone has a clue on this? In the previous revision of this datasheet, Pin 1 is bottom left . Already burnt 2 mcus because of this...
May 20, 2024 4:34 PM UTC
Smaller circle, bottom left. The others are molding / ejector related.
ST prints the text in top-to-bottom, left-to-right western form. Held in a readable fashion the Pin 1 designation is down and to the left.
May 20, 2024 4:45 PM UTC
My expectation is that legitimate parts will have a common VSS bonding, which you could continuity check to confirm orientation expectations.
Could perhaps look for other boards, orientation, where VCC and GND enter, HSE placed, SWDIO/SWCLK and VCAPs (where used)
waclawek.jan
May 20, 2024 5:06 PM UTC
This appears to be a regression in rev4 of the DS:
@Imen.D, can you please have a look at this? Thanks.
May 23, 2024 3:25 PM UTC
Hi @waclawek.jan,
All device markings are being removed from the Datasheet and are being moved to the Technical note: Reference device marking schematics for STM32 microcontrollers and microprocessors.
May 23, 2024 4:26 PM UTC
Someone should also have a word with the graphics dept.. about unhelpful imagery
waclawek.jan
May 23, 2024 3:57 PM UTC
Hi @Imen.D ,
Okay, and is/will be there a link/pointer to that document in the datasheets themselves, or is it upon us to spread the gospel?
Thanks,
Jan
Muhammed Güler
Senior III
May 23, 2024 4:01 PM UTC
On most ICs, the bottom row of the label contains the first pin.
May 23, 2024 4:15 PM UTC
Which is great advice until it's not..
You should have a conversation with my pick-n-place guy some day..
Muhammed Güler
Senior III
May 23, 2024 4:53 PM UTC
I've never encountered an IC labeled like this before. Until you showed me this picture, I believed there was a standard for IC naming that I didn't know about.
