nmamore
Jul 14, 2021 19:35 UTC
STM32F103 Reduce VBAT Current
My datasheet (STM32F103VC) states the Vbat current draw is 1.4uA. Is there a way to reduce this? I only need the backup domain for RTC/LSE. I know there are many backup registers as well. Could I turn these off to reduce current draw?
Jul 14, 2021 20:21 UTC
The backup domain cannot be partially disabled.
nmamore
nmamoreAuthor
Jul 14, 2021 20:38 UTC
Thank you. Are you familiar with any possible ways that I could further reduce current draw?
Jul 14, 2021 22:47 UTC
You could reduce the voltage to the minimum allowed. I don't think there's anything else you can do apart from that, but I'm not an expert in low power applications.
Logically, if there were something easy that could be done to reduce the current, it would be silly of them not to use the lower value in the datasheet.
waclawek.jan
Jul 14, 2021 23:48 UTC
Use a different STM32 model, e.g. 'L4 - you can have mostly pin and function compatibility and roughly 2-3x lower IVBAT.
Most of the current goes to LSE/RTC. For even lower battery consumption use a well-chosen external RTC.
