Stepan Podhorsky
STM32F CAN messages filtering
  • March 23, 2017
  • 1 reply
  • 968 views
Posted on March 23, 2017 at 11:40
I would like to ask you for an advice regarding the CAN messages
filtering. I am not sure whether I understand the filtering and masking
in right manner. I have following settings
CAN_FilterConfTypeDef
filt;
filt.
FilterIdHigh
= (0x6C1 << 5)
; // standard 11 bit identifier
filt.
FilterIdLow
= 0
filt.
FilterMaskIdHigh
= 0
filt.
FilterMaskIdLow
= 0
and I am not sure what ID's will be captured by the CAN periphery. I expect that
all CAN frames will be captured because the mask has all bits zero. Is it correct?
If it is incorrect what ID's will be captured?
Thanks.
#stm32f #can
1 reply
Stepan Podhorsky
Posted on March 26, 2017 at 17:18
CAN frame is accepted only if (id & mask == filter) logic statement has true value. So the above setting results in no frames to be accepted.
Tesla DeLorean
Guru
March 26, 2017
Posted on March 26, 2017 at 18:38
Use this mask to filter the specific message you are looking for
filt.
FilterMaskIdHigh
= 0x7FF << 5
Stepan Podhorsky
Posted on March 26, 2017 at 21:02
Thanks Clive One.
