Microstar
STM32Cube indent using 2 spaces, How can I change it to 4 spaces?
  • March 27, 2018
  • 14 replies
  • 9366 views
Posted on March 27, 2018 at 05:29
exp:
void function(void) {
  int cubemode;
    int iexpect;
#indent
    Mich1
    I hope it will be done one day
    nguyennhantinh
    Explorer
    June 15, 2019
    Replace '#t' by '#t#t' all file in "Program Files \STMicroelectronics\STM32Cube\STM32CubeMX\db\templates"
    Mich1
    we can see in these files:
    [#if nTab==2]#t#t[#else]#t[/#if]
    Could it be possible to define nTab somewhere?
    Microstar
    MicrostarAuthor
    This may be a simpler way. I‘ll try.
    WWawr
    I used a PowerShell command for this:
    (With Administrator privileges) here C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeMX\db\templates>
    Get-ChildItem *.ftl -Recurse | ForEach { (Get-Content $_ | ForEach { $_ -replace 'nTab=1', 'nTab=2' }) | Set-Content $_ }
    Seems to work
    StefanRickli
    This hasn't been addressed yet, or has it?
    Edimahler
    Same question here. Would be a really tiny work for ST to finally implement this and would save us hours of "redesigning" the code every time again, when creating a new project.
    Edimahler
    BTW: Does anybody knows, where to find the template files of CubeIDE in order to edit them using the Powershell way mentioned above?
    BDinh.1
    Here is my instructions, worked well for me,
    # find your STM32CubeMX.jar, make backup if necessary
    find /opt/st/stm32cubeide STM32CubeMX.jar
    # copy to temporary directory
    cp STM32CubeMX.jar /tmp/test
    # download Java Jar explorer and decompiler
    https://github.com/Col-E/Recaf
    # use recaf to navigate to com/st/microxplorer/codegenerator/CodeEngine.class
    search for replace("#t", " "), right click to the containing function "cleanCode", find for string " ", change to " "
    # save the new jar file by File > Export Program
    # close recaf, double check by reopen new jar file and confirm #t is now 4 spaces.
    # restore new STM32CubeMX.jar to the original location
    BDinh.1
    Check out my pre-patched cubemx here:
    https://github.com/jetacpp/stm32cube_patch.git
    NRatz.2
    Found it. In Windows > Preferences > General > Editors > Text Editors
    Check "Insert spaces for tabs"
    DBart.12
    Visitor II
    April 19, 2023
    Hey, ST, any way to add a simple option in CubeMX to toggle that?
