cacciu
[SOLVED] Having Trouble with Tim1
  • October 28, 2019
  • 10 replies
  • 2663 views
[SOLVED]
Hi
I'm Pretty new to stm and i want to communicate to 4 ESC's.
I have the STM32F446VET and am using TIM1-4 each with channel 1.
 * @brief TIM1 Initialization Function
 * @param None
 * @retval None
static void MX_TIM1_Init(void)
 /* USER CODE BEGIN TIM1_Init 0 */
 /* USER CODE END TIM1_Init 0 */
 TIM_MasterConfigTypeDef sMasterConfig = {0};
 TIM_OC_InitTypeDef sConfigOC = {0};
 TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
 /* USER CODE BEGIN TIM1_Init 1 */
 /* USER CODE END TIM1_Init 1 */
 htim1.Instance = TIM1;
 htim1.Init.Prescaler = 74;
 htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
 htim1.Init.Period = 19999;
 htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
 htim1.Init.RepetitionCounter = 0;
 htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
 if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
 Error_Handler();
 sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
 if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
 Error_Handler();
 sConfigOC.OCMode = TIM_OCMODE_PWM1;
 sConfigOC.Pulse = 0;
 sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
 sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
 sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
 sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
 sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
 if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
 Error_Handler();
 sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
 sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
 sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
 sBreakDeadTimeConfig.DeadTime = 0;
 sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
 sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
 sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
 if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN TIM1_Init 2 */
 /* USER CODE END TIM1_Init 2 */
 HAL_TIM_MspPostInit(&htim1);
 * @brief TIM2 Initialization Function
 * @param None
 * @retval None
static void MX_TIM2_Init(void)
 /* USER CODE BEGIN TIM2_Init 0 */
 /* USER CODE END TIM2_Init 0 */
 /* USER CODE BEGIN TIM2_Init 1 */
 /* USER CODE END TIM2_Init 1 */
 htim2.Instance = TIM2;
 htim2.Init.Prescaler = 74;
 htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
 htim2.Init.Period = 19999;
 htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
 htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
 if (HAL_TIM_PWM_Init(&htim2) != HAL_OK)
 Error_Handler();
 if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
 Error_Handler();
 if (HAL_TIM_PWM_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN TIM2_Init 2 */
 /* USER CODE END TIM2_Init 2 */
 HAL_TIM_MspPostInit(&htim2);
 * @brief TIM3 Initialization Function
 * @param None
 * @retval None
static void MX_TIM3_Init(void)
 /* USER CODE BEGIN TIM3_Init 0 */
 /* USER CODE END TIM3_Init 0 */
 /* USER CODE BEGIN TIM3_Init 1 */
 /* USER CODE END TIM3_Init 1 */
 htim3.Instance = TIM3;
 htim3.Init.Prescaler = 74;
 htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
 htim3.Init.Period = 19999;
 htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
 htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
 if (HAL_TIM_PWM_Init(&htim3) != HAL_OK)
 Error_Handler();
 if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
 Error_Handler();
 if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN TIM3_Init 2 */
 /* USER CODE END TIM3_Init 2 */
 HAL_TIM_MspPostInit(&htim3);
 * @brief TIM4 Initialization Function
 * @param None
 * @retval None
static void MX_TIM4_Init(void)
 /* USER CODE BEGIN TIM4_Init 0 */
 /* USER CODE END TIM4_Init 0 */
 /* USER CODE BEGIN TIM4_Init 1 */
 /* USER CODE END TIM4_Init 1 */
 htim4.Instance = TIM4;
 htim4.Init.Prescaler = 74;
 htim4.Init.CounterMode = TIM_COUNTERMODE_UP;
 htim4.Init.Period = 19999;
 htim4.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
 htim4.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
 if (HAL_TIM_PWM_Init(&htim4) != HAL_OK)
 Error_Handler();
 if (HAL_TIMEx_MasterConfigSynchronization(&htim4, &sMasterConfig) != HAL_OK)
 Error_Handler();
 if (HAL_TIM_PWM_ConfigChannel(&htim4, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN TIM4_Init 2 */
 /* USER CODE END TIM4_Init 2 */
 HAL_TIM_MspPostInit(&htim4);
this is the configuration by CubeMx.
My method for Setting the pulse value:
void MSetValue(TIM_HandleTypeDef* htim, uint16_t value)
 sConfigOC.Pulse = value;
 HAL_TIM_PWM_ConfigChannel(htim, &sConfigOC, TIM_CHANNEL_1);
 HAL_TIM_PWM_Start(htim, TIM_CHANNEL_1);
It works for TIM2-4 but not on TIM1. I am trying to do a 20ms cycle with 1060us to 1860us on time(according to the datasheet of the ESC) according to the param value and repeat this indefinitely
since TIM1 is an advanced timer it has a lot more configuration possible.
Thanks and yours
Marco
EDIT: @Community member​ made changes
EDIT 2: i hooked up an oscilliscope and found out, that somehow Tim2-4 and the Tim 1 use different Clocks. When I used a prescaler of 150 (double the one of Tim2-4) it worked.
Tesla DeLorean
Guru
October 28, 2019
TIM_OC_InitTypeDef sConfigOC = {0}; // Avoids random stack junk
These values should be N-1 as they reflect comparator values of last in sequence
htim3.Init.Prescaler = 75;
htim3.Init.Period = 20000;
75 will divide by 76
20000 will divide by 20001
cacciu
cacciuAuthor
thanks, but still, tim2-4 work and tim1 not
Tesla DeLorean
Guru
October 28, 2019
Need to check register content in debugger.
See perhaps if TIM1->CNT is actually changing. If all registers zero, check TIM1 clock enabled on APB2
Check also if PWM Output is enabled, needs to be done explicitly on TIM1/TIM8, MOE bit15 in TIMx_BDTR (+0x44)
berendi
Principal
October 28, 2019
It is't clear from your post, what doesn't work? No output signal at all, wrong frequency, wrong duty cycle, some other problem?
  • Check if TIM1 is enabled at all in RCC->APB2ENR (bit 0).
  • Check that the GPIO ports are clocked in RCC->AHB1ENR, bit 0 or bit 4 depending on which pin is used
  • Check GPIO register bits, MODER and AFRH in particular, that the right alternate function mode and number is selected.
  • Check clock rates. TIM1 runs on APB2 clock, TIM2/3/4 run on APB1 clock, which might be different.
  • Remap TIM1 output to another pin (PA8 or PE9 are possible), don't forget the GPIO clock and AF bits.
  • Compare TIM1 registers with a working timer. Are there differences? What, where?
  • Drop superfluous initialization stuff, a simple PWM output needs neither HAL_TIMEx_MasterConfigSynchronization() nor HAL_TIMEx_ConfigBreakDeadTime()
  • Consider implementing it without HAL, for much shorter and simpler code.
cacciu
cacciuAuthor
I sadly do not have an oscilloscope at Hand,
i'll do that, thanks. I feel much more comfortable using hal, because i do not know which Register what does and it's a lot of work to look each and every Register up.
waclawek.jan
Read out the content of TIM1 registers and relevant GPIO registers and check/post.
cacciu
cacciuAuthor
thank you for your answers.
(Although strangely my oscilloscope showed that with a prescaler of 75 i had the correct Timing according to the ESC's datasheet and Tim2-4 had double the Speed (100Hz). I don't know what happend, but it works now.)
My best guess is that Tim1 uses APB1 Timer Clock and TIM2-4 use the APB1 peripheral Clock...
berendi
Principal
October 31, 2019
Instead of guessing, you can look it up in the reference manual. Chapter 6.2, Clocks.
TIM1 uses APB2 timer clock, TIM2-4 use APB1 timer clock.
You can see which timers are connected to which domains by looking at how their clocks gets enabled. Look at the RCC_APB1ENR and RCC_APB2ENR registers.
This question would have been a lot easier to answer if you had mentioned the period was twice (or half) of what you expected instead of just saying "doesn't work."
cacciu
cacciuAuthor
Well I do not own an oscilloscope and then went to a hackerspace to take a look at it.
