samiassaad
RTC calibration
  • April 6, 2011
  • 1 reply
  • 694 views
Posted on April 06, 2011 at 13:08
RTC calibration
    1 reply
    Tesla DeLorean
    Guru
    May 17, 2011
    Posted on May 17, 2011 at 14:30
    You could measure the 1 Hz RTC tick against ticks of the HSI or HSE clocks over the 1 second observation period.
    They both have better accuracy than the ~40 KHz 8% LSI, not that the LSI has any voltage or temperature stability to be worth calibrating. Unless you have some way to sync against an external source (GPS, NTP, 1588) periodically, you will have trouble maintaining an accurate time.
    Using a more accurate LSE source would be a more productive choice.
