mahmoud boroumand
RCC HSE CONFIG
  • July 17, 2017
  • 3 replies
  • 678 views
Posted on July 17, 2017 at 07:01
hey
I'm use stm32f013cbtx and 8MHz crystal connect to HSE And use standard peripherals library with Keil v5.
How can i config micro-controller for 72 MHz clock(with Cmsis)?is it possible?
    Vangelis Fortounas
    Posted on July 17, 2017 at 09:05
    Hello!
    The 'system_stm32f10x.c' in your project contains the clock configuration function 'void SetSysClock(void)'  This function configures the RCC
     open Menu-> project-> option-> C/C++ tab .
    At 'Define' text box  must  be a definition(at least)  'USE_STDPERIPH_DRIVER, HSE_VALUE=8000000, STM32F10x'  whithout quotes.
    This definition will configures your clock to 72 MHZ
    mahmoud boroumand
    Posted on July 17, 2017 at 09:30
    thanks .its work well
    Nesrine M_O
    Posted on July 17, 2017 at 16:13
    https://community.st.com/0D50X00009bMM5DSAW
