BoboyeOkeya
PWM Output on STM32F031C6TX
HI all,
Does anyone know how to configure the One Pulse mode on this chip using the HAL library?
I tried producing a constantly on-pulse on a timer by setting the CCR value to be greater than the ARR value. And it produced no output
P.S: I accounted for the fact that the processor adds +1 to the value of the ARR and it still didnt work.
Any help would suffice
Tesla DeLorean
Guru
November 1, 2021
Which TIM? The Advanced timers (TIM1 and TIM8 generally) need PWM Output to be explicitly enabled (MOE?)
BoboyeOkeya
It is the Advanced timer TIM1.
Here is the configuration code
 * @brief TIM1 Initialization Function
 * @param None
 * @retval None
static void MX_TIM1_Init(void)
 /* USER CODE BEGIN TIM1_Init 0 */
 /* USER CODE END TIM1_Init 0 */
 TIM_ClockConfigTypeDef sClockSourceConfig = {0};
 //TIM_ClearInputConfigTypeDef sClearInputConfig = {0};
 TIM_SlaveConfigTypeDef sSlaveConfig = {0};
 TIM_MasterConfigTypeDef sMasterConfig = {0};
 TIM_OC_InitTypeDef sConfigOC = {0};
 TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
 /* USER CODE BEGIN TIM1_Init 1 */
 /* USER CODE END TIM1_Init 1 */
 htim1.Instance = TIM1;
 htim1.Init.Prescaler = HF_TIMX_PSC;
 htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
 htim1.Init.Period = HF_TIMX_ARR;
 htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
 htim1.Init.RepetitionCounter = 0;
 htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
 if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
 Error_Handler();
 sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
 if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
 Error_Handler();
 if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
 Error_Handler();
// sClearInputConfig.ClearInputState = ENABLE;
// sClearInputConfig.ClearInputSource = TIM_CLEARINPUTSOURCE_ETR;
// sClearInputConfig.ClearInputPolarity = TIM_CLEARINPUTPOLARITY_NONINVERTED;
// sClearInputConfig.ClearInputPrescaler = TIM_CLEARINPUTPRESCALER_DIV1;
// sClearInputConfig.ClearInputFilter = 8;
// if (HAL_TIM_ConfigOCrefClear(&htim1, &sClearInputConfig, TIM_CHANNEL_1) != HAL_OK)
// Error_Handler();
// if (HAL_TIM_ConfigOCrefClear(&htim1, &sClearInputConfig, TIM_CHANNEL_2) != HAL_OK)
// Error_Handler();
// if (HAL_TIM_ConfigOCrefClear(&htim1, &sClearInputConfig, TIM_CHANNEL_3) != HAL_OK)
// Error_Handler();
 sSlaveConfig.SlaveMode = TIM_SLAVEMODE_RESET;
 sSlaveConfig.InputTrigger = TIM_TS_ITR1;
 if (HAL_TIM_SlaveConfigSynchronization(&htim1, &sSlaveConfig) != HAL_OK)
 Error_Handler();
 sMasterConfig.MasterOutputTrigger = TIM_TRGO_OC4REF;
 sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_ENABLE;
 if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
 Error_Handler();
 sConfigOC.OCMode = TIM_OCMODE_PWM1;
 sConfigOC.Pulse = 0;
 sConfigOC.OCPolarity = TIM_OCPOLARITY_LOW;
 sConfigOC.OCNPolarity = TIM_OCNPOLARITY_LOW;
 sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
 sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
 sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
 if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
 Error_Handler();
 if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
 Error_Handler();
 if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
 Error_Handler();
 sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
 if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
 Error_Handler();
 sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
 sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
 sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
 sBreakDeadTimeConfig.DeadTime = 0;
 sBreakDeadTimeConfig.BreakState = TIM_BREAK_ENABLE;
 sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_LOW;
 sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
 if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN TIM1_Init 2 */
#if (CURRENT_MODE != 0)
 LL_TIM_DisableBRK(htim1.Instance);
#endif
 LL_TIM_OC_SetDeadTime(htim1.Instance, DEAD_TIME);
 /* USER CODE END TIM1_Init 2 */
 HAL_TIM_MspPostInit(&htim1);
Tesla DeLorean
Guru
November 1, 2021
 /* Start channel 1 */
 if (HAL_TIM_PWM_Start(&TimHandle, TIM_CHANNEL_1) != HAL_OK)
  /* PWM Generation Error */
  Error_Handler();
or explicitly
  /* Enable the main output */
  __HAL_TIM_MOE_ENABLE(htim);
