Private read of I3C target
Garry
hello:
I have a question about I3C private read when I use STM32H563 as a target.
Usually, the number of bytes returned by the target can be set through LL_I3C_ConfigTxPreload, but if the target is uncertain about  how many bytes to return, that is, the number of transmitted bytes is only controlled by the controller, how should the target be configured?
Billy OWEN
Hi @Garry
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Billy
Hi Billy:
Are there any updates?
