NUCLEO-H755ZI-Q and VL53L4CX
  • March 12, 2024
  • 790 views
Hi there,
I want to setup the NUCLEO-H755ZI-Q to run just the microcontroller alongside a VL53L4CX ToF Sensor, I am currently having troubles, can anyone help? I am having troubles configuring the controller and printing values as UART is not configured yet.
Thanks,
Hello @isaacjack
Could you elaborate more your question?
Are you using X-Cube-TOF1 compatible with  VL53L4CX
mƎALLEm
Your issue is not clear! Are you facing a problem with VL53L4CX ToF Sensor or with UART configuration?
Please be more specific.
