tusharrabadiya3
Not able to update option bytes
  • September 2, 2016
  • 6 replies
  • 3892 views
Posted on September 02, 2016 at 11:35
Hi All,
I am working on STM32F429II. Somehow by mistake readout protection is being on. RDP level has set to 1. i am trying to set it 0 by ST-Lint utilities (GUI & CLI both tried). but the message like ''Could not disable Read Out Protection!'' or ''Could not set Option bytes!'' are appeared.
Please Help me out of this.
#option-bytes
slimen
Visitor II
September 2, 2016
Posted on September 02, 2016 at 12:49
Hi rabadiya.tushar,
You need update the latest version of ST-Link utility, and use this to upgrade the STLink firmware (go to ST-LINK>firmware update) or through this Link
http://www.st.com/content/st_com/en/products/embedded-software/development-tool-software/stsw-link009.html
tusharrabadiya3
Posted on September 02, 2016 at 13:54
The problem is still remaining, I have updated both with STM32 ST-Link utility and firmware of ST-Link. While I trying to set option bytes with Target->Option Bytes and select Read Out Protection to Level 0 and selecet ''Apply'' then error is appear like ''Could not set option bytes, Please restart the target and retry!'', screenshot is attached. After doing reset device, problem is same here.
Please help me.
________________
Attachments :
Capture.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I15Y&d=%2Fa%2F0X0000000bi7%2FK_VjZkct8Stgq3EyEcV11VBoB1029H3XmW73ZxAehvQ&asPdf=false
slimen
Visitor II
September 2, 2016
Posted on September 02, 2016 at 17:00
Try the following and then let me know :
1- Set protection level to Level 0
2- Perform a power on reset
3- Use ST-Link Utility again to update option bytes
yann
Visitor II
December 7, 2016
Posted on December 07, 2016 at 08:46
It did not help.
I think I started to have the problem after I updated the software and the hardware to the latest version at this date.
It's also interesting to note despite the error message, the operation completes successfully.
Tesla DeLorean
Guru
December 7, 2016
Posted on December 07, 2016 at 10:28
If you suspect something is wrong with the software you have running on the device (ie it is reprogramming the options, or reconfiguring GPIO pins), then pulling BOOT0 High will run the System Loader instead of the User Code, and things might function in a more stable fashion.
