LMorr.3
Jun 30, 2023 5:34 PM UTC
Neucleo Dev Board Schematic
Is there a schematic or a reference design similar to the one used for the Neucleo boards?
I'm thinking of spinning up my own board instead of using a neucleo, and wanted to include design elements like the debug link, boot loader link, oscillators, caps. etc.
My other option is just to use the datasheet for design recommendations to make my own board, and add debugging and firmware update connections to I can use CubeMX to prototype and then use a serial connection to allow firmware updates on production build.
AScha.3
AScha.3Best answer
Jun 30, 2023 5:52 PM UTC
see nucleo boards, board schema...
https://www.st.com/en/evaluation-tools/nucleo-f303re.html#cad-resources
ie https://www.st.com/resource/en/schematic_pack/mb1136-default-c05_schematic.pdf
ok?
1 reply
AScha.3
AScha.3Best answer
