Stark
make all make: *** No rule to make target ...
  • April 14, 2023
  • 8 replies
  • 19743 views
Hello everyone,
​I use GPIO example project (from repository of ST) and open it by STM32 cube IDE. then when I built it give error:
make all
How to fix this error?
Thank you! Sorry cause my English not good.
    Best answer by KnarfB
    Do not copy the example, but open the project in the repository tree. The projects use relative paths to the Drivers folder.
    KnarfB
    You have opened the folder, but not the project. The project file is in the SW4STM32/STM32F030R8-Nucleo subfolder. Look for a .project file (may not be visible depending on your explorer settings).
    Use File > Open projects from file system to import the project in your current workspace.
    The imported project should have a blue "IDE" icon and build without errors.
    hth
    KnarfB
    Stark
    StarkAuthor
    i open .project file (or open from file system) but it still error.
    Pavel A.
    April 14, 2023
    Clean the project then Refresh. Then try to build again.
    Stark
    StarkAuthor
    it still has that error
    Stark
    StarkAuthor
    here are the steps i took:
    1. copy GPIO example project ​ in repository of ST from ​(C:) disk
    2. open folder GPIO project > SW4STM32 > ".project" and cube ide opened, then i built it. it error "no such file or directory" and when I include path, it error "make: *** No rule to make target ..." as name's topic.
    KnarfB
    KnarfBBest answer
    Stark
    StarkAuthor
    Wow! It done. Thank you very so much! very impressive! Bravo!​
    Thanks everyone! I spent a lot of time on that error
    In my case I opened the .cProject in place [downloaded the entire repository, and then opened:
    this
    "G:\H5_GITHUB_EXAMPLE\Projects\NUCLEO-H563ZI\Examples\GPIO\GPIO_IOToggle_TrustZone\STM32CubeIDE\.project"
    and I'm getting all red with the same error message:
    Description Resource Path Location Type
    make: *** No rule to make target 'G:/H5_GITHUB_EXAMPLE/Drivers/STM32H5xx_HAL_Driver/Src/stm32h5xx_hal.c', needed by 'Drivers/STM32H5xx_HAL_Driver/stm32h5xx_hal.o'. Stop. GPIO_IOToggle_TrustZone_Secure C/C++ Problem
