ham10za
internal flash
  • February 19, 2018
  • 29 replies
  • 5101 views
Posted on February 19, 2018 at 09:57
hello! i am working with stm32 cortex-M0? IN FACT i want to know how to modify bytes from the internal flash without erasing the whole page , in addition i don't have RAM space to copy code there and modify bytes there !! is there anyone who can help ?
Note: this post was migrated and contained many threaded conversations, some content may be missing.
    Andrew Neil
    Posted on February 19, 2018 at 10:20
    When cross-posting (ie, posting the same question to multiple forums), always include links between the threads.
    Otherwise you waste people's time as they give an answer in one thread - not knowing that it has already been given in another.
    See:
    http://www.keil.com/forum/63375
     on the Keil forum.
    ham10za
    ham10zaAuthor
    Posted on February 19, 2018 at 10:43
    you told me to ask on ST forum !!
    Andrew Neil
    Posted on February 19, 2018 at 12:05
    See:
    https://community.st.com/0D50X00009XkWg8SAF
    OK, so I should have spelled it out to you at that point.
    Alan Chambers
    Posted on February 19, 2018 at 12:49
    Perhaps you should explain what exactly are you trying to achieve. What are you using the flash to store? How big is the data structure? How often does it change?
    Andrew Neil
    Posted on February 19, 2018 at 13:14
    Absolutely!
    http://www.catb.org/~esr/faqs/smart-questions.html ♯ goal
