IAR Project -> ARM GCC Project
Posted on November 17, 2017 at 05:00
Hello Dave,
This is the request not related to the topic above. I wanted to build the source code for steval-esc001 using AC6 GCC compiler can i build it or should be built only using IAR. please share if you have any idea about it or help me out regarding the issue. because i am using steval-spin32 building using AC6. I dont have license for IAR. more relaying on opensource GCC.
lohit
