kjosh.1
i am sanding data too my serial monitor to uart2 and uart to data transmit and received and transmit to uart6 and uart 6 received and and transmit back my serial monitor plz help i am working stm32f411vet6 microcontroler
  • March 23, 2023
  • 17 replies
  • 3774 views
waclawek.jan
Is there a question?
kjosh.1
kjosh.1Author
yes
kjosh.1
kjosh.1Author
i am sanding data my serial monitor to uart2 ,uart2 received data and transmit to uart6 ,uart6 received data and transmit back to serial monitor with stm32f411 microcontroller plz give me answer
kjosh.1
kjosh.1Author
Tesla DeLorean
Guru
March 23, 2023
Repeating the same information is not going to move this forward. When prompted like this it means your question lacks structure or detail
What isn't working?
Show initialization code, clocks, pins, etc
Show code that doing the interaction
Tesla DeLorean
Guru
March 23, 2023
You want code showing forwarding back and forth between UART2 <-> UART6 ?
What board are you using?
Which pins are connected to the UARTs ?
kjosh.1
kjosh.1Author
stm32f411vet6 microcontroller using
kjosh.1
kjosh.1Author
and i am using mx 32 cube id and using hadware bord uart2 and uart6 and yp-05 card using one card using to uart2 and one is using for uart6
Tesla DeLorean
Guru
March 23, 2023
So this YP-05, that's some USB-to-CMOS dongle?
You still haven't asked a question, you keep make statements.
What do you want people here to do?
Write the code for you?
Figure out what pins you're using?
Find some UART examples for your board or the F4 generally, adapt.
kjosh.1
kjosh.1Author
i am conected tx and rx , PA2TX ,PA3RX FOR UART2 AND PC6 OR PC7 FOR UART6
kjosh.1
kjosh.1Author
muje seniar monitor(user enter any data) se uart2 per data bhejna hai aur uart to se data uart6 per bhejna hai aur uart6 se data vaps serial monitor ko bhejna hai mera bord stm32f411vet6 hai iska code btao plz
Tesla DeLorean
Guru
March 23, 2023
Create the code to initialize the two UARTs
Then in your main loop
Receive any pending content from UART2, and Transmit to UART6
Receive any pending content from UART6, and Transmit to UART2
To avoid data loss you might want to use a FIFO buffer to give you some elasticity
Not sure there's a lot of people here who want to do homework assignments
kjosh.1
kjosh.1Author
plz give code bacuse method not working i am tired
kjosh.1
kjosh.1Author
not working please give code
Karl Yamashita
Principal
March 31, 2023
Check this post that I replied to. From PC>UART2>UART1 where UART1 is in loopback. Then UART1>UART2>PC
https://community.st.com/s/question/0D53W00002CeLaOSAV/cannot-receive-full-string-on-uart-receive-st32h745-disco-board
If a reply has proven helpful, click on Accept as Solution so that it'll show at top of the post.CAN Jammer an open source CAN bus hacking toolCANableV3 Open Source
