Priyadarshini Solanki
How to use Linker exported symbol in an application?
  • April 5, 2019
  • 1462 views
I am using #[STM32 MCUs]​ #Cortex-m0​ . In linker file we have symbol: __ICFEDIT_region_ROM_start__
How we can use this symbol in application ?
I have assigned &__ICFEDIT_region_ROM_start__ to Pointer.
i.e int *p = &__ICFEDIT_region_ROM_start__
now using p we can fetch the data define by symbol __ICFEDIT_region_ROM_start__.
I want that data to be in macro definition. How i can use?
#define ROM_address   __ICFEDIT_region_ROM_start__ ( ROM_address holds wrong data )
    Best answer by After Forever
    Try this way:
    extern uint32_t __ICFEDIT_region_ROM_start__;
    #define ROM_address ((void *)(&__ICFEDIT_region_ROM_start__))
    Or change (void *) to whatever pointer type you require. And turn off compiler's strict aliasing rules to be safe (-fno-strict-aliasing option in GCC)
    After Forever
    After ForeverBest answer
    Senior III
    April 5, 2019
    Try this way:
    Thanks for the response.
    It's perfectly working as expected.
