Xli.1
How to use DMA to change PWM frequency?
  • May 24, 2020
  • 806 views
hi guys. I want to use DMA to change the PWM frequency in the pwm running. I used DMA to change the ARR of Tim, but it was failed. So how to change the pwm frequency by DMA?
waclawek.jan
By changing ARR of TIM. You'll need to have ARR preload enabled (TIMx_CR1.ARPE=1)..
Post details.
