SA V.1
How to interface AD7768-4FMCZ with STM32F103RCT6 using SPI in Keil or STMCube IDE i need this complete Source and Application code
  • September 10, 2022
  • 3 replies
  • 1011 views
Tesla DeLorean
Guru
September 10, 2022
You'll likely need to pull the documentation and available examples, and then port to your platform.
SA V.1
SA V.1Author
I asked a source or application code related to above .can u share the developped code or code link ??
Tesla DeLorean
Guru
September 14, 2022
Perhaps you can discuss ​those needs with the software engineers working on your project.
T​he part combinations here are relatively specialized / niche. If you can't find code to copy-n-paste, you might have to get more involved in coding a solution.
