sumalatha
how to count the 12 bit ADC count
  • October 3, 2010
  • 11 replies
  • 2648 views
Posted on October 03, 2010 at 11:41
    Andrew Neil
    Posted on May 17, 2011 at 14:09
    and sending it to Hyperterminal (or any other application) is a matter of using the USART - again, see examples provided with the library...
    raptorhal2
    Lead
    May 17, 2011
    Unfortunately ''count'' is not a very helpful term. When the ADC converts an input analog channel, it returns an unsigned integer value. For zero or negative input volts, it returns a value of zero. For 3.3 or higher volts, it returns a value of 4095. (Don't go too negative or too high to avoid damaging the ADC). In between zero and 3.3 volts, the ADC returns a corresponding ratioed value.
    No ''counting'' is required, just a simple read.
    Look at the examples in the Library for further information on how to convert and read a channel.
    If I have misunderstood your question, please restate.
    Cheers, Hal
    Andrew Neil
    ''i didnt see the count value in hyperterminal''
    Nothing in the code you've shown writes anything to the USART!
    Remember: to the STM32, Hyperterminal is irrelevant!
    All the STM32 knows is that it transmits bytes through the USART - where those bytes go from there is entirely immaterial to the STM32.
    See:
    [DEAD LINK /public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/ARM CortexM3 STM32/Hyperterminal is not the only terminal program!!&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E]https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fARM%20CortexM3%20STM32%2fHyperterminal%20is%20not%20the%20only%20terminal%20program%21%21&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E
    sumalatha
    sumalathaAuthor
    Thanx for replying ...
    actualy in my application my data (Analog temperature value ) i want read this so i am confg here
    RCC_Configuration();
     SYSTICKS_Configuration();
      GPIO_Config();
        TIM2_Configuration();
        NVIC_Configuration();
        USART_Configuration(DBG_USART,115200);
       ADC_Config();
    for read this channel....
    u16 readADC1(u8 channel)
      ADC_RegularChannelConfig(ADC1, channel, 1, ADC_SampleTime_55Cycles5);
      // Start the conversion
      ADC_SoftwareStartConvCmd(ADC1, ENABLE);
      // Wait until conversion completion
      while(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC) == RESET);
      // Get the conversion value
      return ADC_GetConversionValue(ADC1);
    but i didnt see the count value in hyperterminal so plz tel me what is the thing is wrong
    thanx
    Andrew Neil
    How have you verified that your WriteSerial() routine actually works?
    eg, have you tried it with a simple ''Hello, world'' program?
    Remember that serial comms is very, very slow relative the CPU execution - how do you ensure that the USART is ready before you call WriteSerial() again...?
    sumalatha
    sumalathaAuthor
    thanx andrew  in main ()
    while(1)
          //u16 readADC1(u8 channel);
            ADC_val=ADC_GetConversionValue(ADC1);
            WriteSerial(DBG_USART,''count '');
           Second_Delay(3);
            WriteSerial(DBG_USART,ADC_val);
            WriteSerial(DBG_USART,''\r\n'');
    Andrew Neil
    You still haven't showed the code of your WriteSerial() function!
    And you still haven't said how you know that it actually works at all!
    But this doesn't look right:
    Here, you are passing a string to it:
        WriteSerial( DBG_USART, '' hello \r\n'' );
    But here, you are passing a u16 integer value:
    WriteSerial( DBG_USART, ADC_val );
    That can't be right, surely??!
    sumalatha
    sumalathaAuthor
    Dear Andrew….Thanx for reply…
    Actually I want to disply the ADC count on USART
    and this my code
    int main(void)
    u16 ADC_val;
    GPIO_Config();
    Delay_Ms(500);
    Delay_Ms(500);
    WriteSerial(DBG_USART,'' hello \r\n'');
    Delay_Ms(500);
    ADC_Config();
    while(1)
    ADC_val=ADC1ConvertedValue;
    //strcat(ADC_val,'':'');
    //sprif(ADC_val,ADC_val);
    WriteSerial(DBG_USART,''SJA '');
    Second_Delay(3);
    //WriteSerial(DBG_USART,''ADC_val'');
    And ADC config
    void ADC_Config(void)
    ADC_InitTypeDef ADC_InitStructure;
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_NbrOfChannel = 1;
    ADC_Init(ADC1, &ADC_InitStructure);
    /* ADC1 regular channel5configuration */
    ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 1, ADC_SampleTime_55Cycles5);
    /* Enable ADC1 DMA */
    //ADC_DMACmd(ADC1, ENABLE);
    /* Enable ADC1 */
    ADC_Cmd(ADC1, ENABLE);
    /* Enable ADC1 reset calibaration register */
    ADC_ResetCalibration(ADC1);
    /* Check the end of ADC1 reset calibration register */
    while(ADC_GetResetCalibrationStatus(ADC1));
    /* Start ADC1 calibaration */
    ADC_StartCalibration(ADC1);
    /* Check the end of ADC1 calibration */
    while(ADC_GetCalibrationStatus(ADC1));
    /* Start ADC1 Software Conversion */
    while (1)
    ADC_RegularChannelConfig(ADC1, 5, 1, ADC_SampleTime_55Cycles5);
    //return ADC_GetConversionValue(ADC1);
    ADC1ConvertedValue = ADC_GetConversionValue(ADC1);
    // -------------- The ADC IRQ handler
    void ADC1_2_IRQHandler(void)
    // Clear ADC1 EOC pending interrupt bit
    ADC_ClearITPendingBit(ADC1, ADC_IT_EOC);
    // Get converted value of Channelxx converted by ADC1
    cADC1_BUF1[cnt++]=ADC1ConvertedValue;
    WriteSerial(DBG_USART,cADC1_BUF1);
    if(cnt==128)
    cnt=0;
    In hyper
    only hello is displayed nt ADC_val
    Y it is not displayed? Iam confusing plz help me.:-).
    Andrew Neil
    Sorry - stupid forum playing up again!
    Andrew Neil
    ''Perhaps you should convert the number into ASCII before pushing it out to the serial port?''
    Indeed!
    The commented-out lines suggest that she might have been trying to do that:
    But there seem to be some basic problems there with (lack of) understanding how strings work in the 'C' programming language...?
