Hard Fault problem
igor2399
Posted on March 23, 2011 at 10:10
Hard Fault problem
5 REPLIES 5
Posted on May 17, 2011 at 14:29
08002ace:   str r2, [r3, #0] << Could it be faulting here. What is in R3?
igor2399
igor2399
Yes, the problem was that!
There was an uninitialized pointer :(
And it wasn't signaled by the IDE!! :( :(
I did a lot of noise for a stupid problem... Sorry!
Thaks Clive1 for the illuminating hint! :)
I.
No problem, you'll catch it the next time.
NULL or invalid pointers are a classic cause of Hard Faults, and the address you were pointing to looked just fine. So I looked at the next most likely reason.
Was Atollic pointing you at this address, or do you have some fault handler code, like Joseph Yiu's example?
igor2399
