var2
Flash loader demonstrator V2.6.0 command line problem
  • March 27, 2013
  • 719 views
Posted on March 27, 2013 at 10:59
I did not receive response for my previous question;
Here is the exact description of the problem.
Command below
c:\''Program files\STMicroelectronics\Software\Flash Loader Demonstrator''\STMFlashLoader.exe -?
returns
bad parameter [files\STMicroelectronics\Software\Flash]
message.
This is bag.  The version 2.4.0 works correctly.
To the STMicroelectronics software designers.  This is obviously bag in the
STMFlashLoader.exe command line parser.
Please, check and correct the problem.
    trevor23
    Posted on March 27, 2013 at 11:46
    Have you tried with quotes around the whole file path i.e.
    ''c:\Program files\STMicroelectronics\Software\Flash Loader Demonstrator\STMFlashLoader.exe'' -?
    var2
    var2Author
    Posted on March 27, 2013 at 12:07
    Thank you very much!
    It works.
