DIfferent Vector tables or single one
rajivpatil61
Posted on December 18, 2014 at 11:57
now I have 2 hex files running independently, to perform context switching i am using a systick timer, now should i use a single vector table to link them by calling same ISR, or define 2 Vector tables and call 2 different ISRs. In either case how to link them.
ivani
Posted on December 18, 2014 at 13:20
Sounds like a good reason to switch to RTOS.
Besides this there is no need to alter the vector table just to change the behavior of the ISR. You could do it by a global state variable, which indicates the last action performed by the ISR.
Posted on December 18, 2014 at 14:02
Perhaps there is a better way to partition the functionality?
You could put the vector table in RAM and then register each interrupt vector/routine in a more dynamic fashion.
