Debuggin isseue
Kai_Satone
tjaekel
Lead
"hmmmm".....?
Imen.D
Hello @Kai_Satone ,
Please post more details on your case (share the entire debug log), so that it will be easier to understand the root cause.
Otherwise, I advise you to check the Debug configuration in the CubeIDE and make sure to select the adequate external loader. Check also your board stack size.
Imen
CMYL
Hello @Kai_Satone
Can you give more details on the issue ?
- STM32 family used
- STM32CubeIDE version, project setting
- STM32CubeMX *.IOC project if this tool is used ...
Best regards
