TSlat.1
Visitor II
June 16, 2020
Copyright on firmware libs / CubeMX software and git repositories
  • June 16, 2020
  • 0 replies
  • 487 views
I created a project using the CubeMX software, as the basis for a music playing device.
I then used the SD disk io dma rtos driver from the wav player/recorder as the cube generated code is broken.
Can I put a project on github using the above code?
I've left the copyright agreements in place, but perhaps modified header references in places. Can anyone (perhaps an ST rep) provide guidance here?
