LKuri.1
Can't update GPIOx_MODER register value in STM32H753.
  • December 31, 2020
  • 820 views
I work with STM32H753 through 3-rd side hardware (Algocraft WN-1 programmer) and have an access to the registers. I try to read/write GPIOJ pins. For this purpose I enabled GPIOJ clock by writing the AHB4 peripheral clock enable register (RCC_AHB4ENR)
// Write to AHB4 peripheral clock enable register (RCC_AHB4ENR) to enable GPIOJ
#prog -o cmd -c write -t h580244e0 -l 4 --data h00000200 --mask h132807ff
#prog -o cmd -c compare -t h580244e0 -l 4 --data h00000200 --mask h132807ff --timeout 6000
and want to define PJ6 pin as common output:
// Write to GPIO port mode register (GPIOJ_MODER) PJ6 - OUT, PJ7 - IN
#prog -o cmd -c write -t h58022400 -l 4 --data h00001000 --mask hffffffff
but always read hffffffff value from this register.
What wrong?
waclawek.jan
And can you change other GPIO registers, e.g. ODR? Can you change other GPIO's registers, e.g. GPIOA?
What does the --mask parameter supposed to do, exactly?
LKuri.1
LKuri.1Author
The mask selects significant bits.
The GPIOA MODER register also includes default data:  0xABFF FFFF.
Data in ODR registers identical to MODER registers.
// Write to AHB4 peripheral clock enable register (RCC_AHB4ENR) to enable GPIOJ , GPIOA
#prog -o cmd -c write -t h580244e0 -l 4 --data h00000201 --mask h132807ff
// Compare the AHB4 peripheral clock enable register (RCC_AHB4ENR) content with expected value.
#prog -o cmd -c compare -t h580244e0 -l 4 --data h00000201 --mask h132807ff --timeout 6000
#data -o set -c out -t file -f \images\RCC_AHB4ENR.bin
#prog -o cmd -c read -m ram -s h0 -t h580244e0 -l 4
// Write to GPIO port mode register (GPIOA_MODER) PA0 - out
#prog -o cmd -c write -t h58020000 -l 4 --data h00000001 --mask hffffffff
// Compare the GPIO port mode register (GPIOA_MODER) content with expected value.
////#prog -o cmd -c compare -t h58020000 -l 4 --data h00000001 --mask hffffffff --timeout 6000
#data -o set -c out -t file -f \images\GPIOA_MODER.bin
#prog -o cmd -c read -m ram -s h0 -t h58020000 -l 4
// Compare the GPIO port mode register (GPIOJ_MODER) content with expected value.
////#prog -o cmd -c compare -t h58022400 -l 4 --data h00001000 --mask hffffffff --timeout 6000
#data -o set -c out -t file -f \images\GPIOJ_MODER.bin
#prog -o cmd -c read -m ram -s h0 -t h58022400 -l 4
// Write to GPIO port mode register (GPIOA_ODR) PA0 - out
#prog -o cmd -c write -t h58020014 -l 4 --data h0000fffe --mask h0000ffff
// Compare the GPIO port mode register (GPIOA_ODR) content with expected value.
////#prog -o cmd -c compare -t h58020014 -l 4 --data h0000fffe --mask h0000ffff --timeout 6000
#data -o set -c out -t file -f \images\GPIOA_ODR.bin
#prog -o cmd -c read -m ram -s h0 -t h58020014 -l 4
// Write to GPIO port mode register (GPIOJ_ODR) PJ6 - OUT, PJ7 - IN
#prog -o cmd -c write -t h58022414 -l 4 --data h0000ff7f --mask h0000ffff
// Compare the GPIO port mode register (GPIOJ_ODR) content with expected value.
////#prog -o cmd -c compare -t h58022414 -l 4 --data h0000ff7f --mask h0000ffff --timeout 6000
#data -o set -c out -t file -f \images\GPIOJ_ODR.bin
#prog -o cmd -c read -m ram -s h0 -t h58022414 -l 4
