Atollic TrueStudio generated a very large elf.bin output file
- October 8, 2018
- 4 replies
- 1177 views
I am trying to generate the elf.bin file from my project which generates elf.hex of size 8329KB where as when i try to generate the elf.bin output it generated of size 30,35,513KB, why is this a too large size, how do i reduce it so that i can use this binary in other application
Attached a screenshot for the generated output files.
Thanks in Advance
