olezhandr
Nov 11, 2021 11:13 AM UTC
Advice, please, how to view the function call tree and the contents of the MCU stack using STM32Cubeide. After the program crashes in debug the program loops in Hard_Fault_Handler () and it is not clear what cause such event.
What ability to view the contents of the call stack in CubeIDE is present?, i.e. what functions were called before the crash, preferably in the form of a tree
KnarfB
KnarfBBest answer
Nov 12, 2021 8:54 AM UTC
If the debugger sits in the while loop, you can set the value of junk to 1 manually and continue stepping out of the handler and back to the code that caused it.
KnarfB
Nov 11, 2021 11:23 AM UTC
You can open the Fault Analyzer View (Windows > Show View > Debug ...) that gives you a little insight.
olezhandr
olezhandrAuthor
Nov 12, 2021 8:31 AM UTC
thanks, i know this method but there is no call tree or stack info
Pavel A.
Nov 12, 2021 1:29 AM UTC
Try to change the while(1) in the Hard_Fault_Handler as follows:
static volatile int junk = 0;
while (!junk) {}
olezhandr
olezhandrAuthor
Nov 12, 2021 8:38 AM UTC
what is it supposed to give?
KnarfB
KnarfBBest answer
olezhandr
olezhandrAuthor
Nov 12, 2021 8:43 AM UTC
KnarfB
Nov 12, 2021 8:49 AM UTC
Yes, you're right.
