TKara.2
The following has evaluated to null or missing Motor Control Workbench
  • February 19, 2024
  • 4 replies
  • 1932 views
The following has evaluated to null or missing I'm getting this error when i try the generate project and i can't click the current mode this stuck on off here is my custom board json file
Best answer by ASA
This issue has been fixed in our new MCSDK 6.3.0 release,
so feel free to download it and try if it solved correctly your issue reported in this post.
Kind Regards.
Amina.
cedric H
Hello @TKara.2 ,
Can you add your stwb6 file to allow us to reproduce your issue.
Thanks.
Cedric
cedric H
I reproduced your issue with 6STEPS algo selection. FOC algo generates successfully. I entered a ticket on dev side and will provide a fix for the coming MCSDK 6.3.0.
Sorry for the inconvenience.
Cedric
TKara.2
TKara.2Author
"Should I wait for version 6.3.0 to run 6 step, or is there a problem with my board settings?"
ASABest answer
Kind Regards.
Amina.
If you agree with my answer, please accept it by clicking on 'Accept as solution'.
