MC 6.3 with MX6.12 - attr not supported : Dmpu
I am trying to generate code for "STM32 Nucleo packs FOC and 6-step motor control platform for three-phase, low-voltage and low-current motor" and I keep getting errors :-
Attr not supported : Dmpu  as in attached image.
I am using cubeMX12, I have updated Java recently and I have uninstalled and reinstalled CubeMX as well. Still no luck. Log file attached.
ASABest answer
Hello @Sujoy_B
this error has been understood and will be corrected in the next version of CubeMx.
Nevertheless, a workaround can be proposed to you in order to avoid having this issue,
Please try after you have deleted the following files :
1- %HOME%\.stm32cubemx\thirdparties\pdsc\EmbeddedOffice.I-CUBE-FS-RTOS.pdsc
2- %HOME%\.stm32cubemx\thirdparties\pdsc\EmbeddedOffice.I-CUBE-FS-RTOS.1.0.1.pdsc
Please tell us if this solves your problem
Kind regards
Amina
If you agree with my answer, please accept it by clicking on 'Accept as solution'.
I am having the same issue as well, using CubeMX version 6.11.1 and MC Workbench 6.3.0. I've tried several different combinations of MC Workbench and CubeMX versions with no success.
Hello @Sujoy_B
Can you give us the version of Java you had recently installed on your PC?
Thanks in advance
Best Regards
Amina
Sujoy_BAuthor
I unistalled JAVA and installed the latest version from https://www.java.com/en/
I believe it is V8 update 411.
Do you need me to share a snapshot?
Hi @Sujoy_B
can you please give us the version of JDK you have on your PC?
ps: the path is commonly : C:\Program Files\Eclipse Adoptium
Thanks for your feedback
Amina
Same issue here. Using old projects with unchanged settings but showing the errors.
Same to me, suddenly started showing the error.
I have this error too. Any luck solving it?
Im not sure what it means and i dont have Java installed.
Hello @Sujoy_B
regarding the log you have attached to your message, the project have been successfully generated, please try to compile it.
The error message is not a blocking one, we are investigating on that nevertheless  you can continue working on your trials.
Thanks a lot for your comprehension
Amina
ASABest answer
Hello @Sujoy_B
Kind regards
Amina
Visitor II
thank you,it is useful on my computer
Hi @Texram
good to hear that you can sucessfully compile your project with any regression.
Please do not hesitate to try the proposed workaround and give us feedback on that.
Amina
Texram
No workaround is needed, just ignore the error messages from Project Generation.
