How to brake a brushless DC motor?
marco siqueira
Hello! I'm trying to smoothly brake a three phase brushless motor, by short circuiting the phases. At this moment an overvoltage occurs damaging the power circuit. Is this the right way to do it? Thanks
Karthik DM
Instead of shorting the phases, I have a another option for you.
Use another one switch(external Switch) when switch is opened it will give high command to MCU. During that time your MCU will stop all PWM.
So this method is smooth than short circuiting the phases.
6 REPLIES 6
Laurent Ca...
Lead II
Dear marco siqueira
Do you have still this problem to solve?
Best regards
Laurent Ca...
marco siqueira
Yes, could you help me?
Karthik DM
Laurent Ca...
Lead II
Dear @marco siqueira​
Does the solution proposed by @Karthik DM​ OK for you?
Best regards
Laurent Ca...
Laurent Ca...
Lead II
I guess it does, therefore I consider this thread closed.
If not, feel free to reopen it by posting an answer.
Best regards
Laurent Ca...
SkyWork
@marco siqueira​
Is it possible to share how to smoothly brake a three phase brushless motor?
