Popeye
[ERROR] - MotorControlProtocol: ASPEP_RESP ERROR:CMD_NOK
  • February 1, 2023
  • 2566 views
Hi, what does this mean?
Using MotorControl V6, motor won't start.
hello @Popeye​ ,
this error means that the command you sent to the firmware does not seem to be recognized.
Can you please tell me what you did to get this error so that I can reproduce the problem and propose a solution.
Thank you
"If you agree with my answer, please accept it by clicking on ""Accept as solution""."
Popeye
PopeyeAuthor
@Zied b.​ , I suspect I got this error because I was unknowingly using the Motor Pilot 6-step GUI for an FOC application. I'll update this thread if that wasn't the issue.
