STTwo-32
STTwo-32Best answer
May 15, 2024 4:57 PM UTC
Hello @Andrew Neil
As you can see on the AN4894 or the Databrief, The X-CUBE-EEPROM doesn't support the STM32F0 series. So, the best guide will be the AN4061as you already said.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @Andrew Neil
Best Regards.
STTwo-32
Andrew Neil
Jun 11, 2024 9:49 AM UTC
@STTwo-32 wrote:
Hello @Andrew Neil
Oh yes - so it does!
So X-CUBE-EEPROM also does not support:
  • STM32F1 - see AN2594 instead;
  • STM32F2 - see AN3390 instead;
  • STM32F3 - see AN4058 instead;
  • STM32F4 - see AN3969 instead;
  • STM32WB - see AN5289 instead.
Update - Sep 2026:
It seems that STM32WB is now supported by X-CUBE-EEPROM:
