scash9
STM32L476 Discovery CDC configuration change
  • October 5, 2016
  • 1 reply
  • 730 views
Posted on October 05, 2016 at 12:48
Hi all,
I'm working on a USB CDC demo from cubel4 family under the STM32L476G_EVAL board.
I port the example to work with the STM32L476_VG_Discovery changing the PIN.
The example configure the board to receive from a USARTx interrupt and transmit from a USARTx_DMA_TX interrupt.
I wanna know how to configure the example to receive and transmit both from the DMA. I must change the configuration in the hal_msp.c and configure the new interrupt USARTx_DMA_RX?
Thank's
#stm32l476 #dma #cdc
1 reply
slimen
Visitor II
October 7, 2016
Posted on October 07, 2016 at 13:26
I recommend to use the STM32CubeMX tool to initialize peripherals, build and generate your starting projects with initialization C code.
STM32CubeMX tool from ST will allow you to choose the microcontroller, select the peripherals you want and map them to pins graphically.
Then, you can follow the ''CDC-Standalone'' example from STM32CubeL4 and modify this working application depending on your needs:
 STM32Cube_FW_L4_V1.5.0\Projects\STM32L476G_EVAL\Applications\USB_Device\CDC_Standalone
For more detail about
http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-configurators-and-code-generators/stm32cubemx.html
tool, take a look to this user Manual
http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM00104712.pdf/files/DM00104712.pdf/jcr:content/translations/en.DM00104712.pdf
For more details, refer to
http://www.st.com/content/ccc/resource/technical/document/user_manual/cf/38/e5/b5/dd/1d/4c/09/DM00108129.pdf/files/DM00108129.pdf/jcr:content/translations/en.DM00108129.pdf
that explains more the use of STM32Cube USb device library.
