AbdurrahmanOnat
STM32F401CDU6 USB CAN'T RECOGNIZE
  • April 21, 2023
  • 1304 views
I have an STM32F401CDU6 blackpill board and I have a USB not recognize code 43 error when activate dfu mode. It's don't do it 3 months ago
Best answer by AbdurrahmanOnat
USB is problematic way with this board (blackpill). If you can buy a ST-LINK programmer (I buy a ST-LINK V2) and programming with this way. No button combination, no problem.
I am close this post now. Thanks to everyone.
Hello @AbdurrahmanOnat​;
Let me first welcome you to the Community :)
Maybe the problem is with your cable, so try a different cable, and make sure that the connections are OK.
Check if the USB_OTG_FS_DP and USB_OTG_FS_DM wires are swapped.
In the USBD_config.h, check you have the correct out-report buffer size (USBD_CUSTOMHID_OUTREPORT_BUF_SIZE)
 Please keep me informed about your progress on this issue.
Imen
AbdurrahmanOnat
Thank you for your friendly welcome.
I tried with a different cable but the result is the same. USB_OTG_FS_DP and USB_OTG_FS_DM wires are not swapped. Because board is worked on 3 monts ago. I can't do any programming process because Windows can not recognize the USB.
Thanks for your attention.
Abdurrahman
AbdurrahmanOnat
AbdurrahmanOnatAuthorBest answer
