Akuma.6
RTOS ThreadX support in STM32G0xxx mcu platform
  • February 8, 2024
  • 4 replies
  • 1812 views
Hi Team
I am using stm32g0x mcu platform. Till now I am writing normal code without using rtos.
Does this mcu support RTOS ThreadX support in STM32G0xxx mcu platform.
Please share the process to enable using Stm32 cubeide tool.
Thanks,
Kumar
Explorer
February 8, 2024
Hi @Akuma.6
Yes STM32G0xx is suppoted by ThreadX
You can find a lot of applications demo in github repo here:
https://github.com/STMicroelectronics/x-cube-azrtos-g0
You can also upload x-cube-azrtos-g0 from cubeMx and generate your code:
Akuma.6
Akuma.6Author
Hi Mohamed Ayed,
Thanks for your response.
I am using the STM32G0B1CC MCU. Will this support once again because given the GitHub have the below boards support:
  • NUCLEO-G0B1RE (MB1360-C02)
  • STM32G0C1E-EV (MB1312-A01)
Regarding my STM32G0B1CC will this support?
Kumar
Explorer
February 11, 2024
As you can see in the link below STM32G0xx series is support so STM32G0B1CC is also supported.
https://github.com/STMicroelectronics/x-cube-azrtos-g0/blob/a5ed457215e8aa2da134bbbdf0c2cbe0ededa5ab/Middlewares/ST/threadx/LICENSED-HARDWARE.txt#L31
Demos in the github repo is a refences application that show the integration of threadx with stm32xx product. I don't thnik that ST can provide more applications with STM32G0B1CC target.
You can start to generate a code STM32CubeMx and  x-cube-azrtos-g0  and manually port any applications.
there is a youtube video playlist show how to start azure rtos step by step
https://www.youtube.com/playlist?list=PLnMKNibPkDnGxMITHhhRqbT0-2egHq0D0
