John Henry
new unprogrammed STM32F303xC into DFU mode
  • April 19, 2018
  • 3 replies
  • 831 views
Posted on April 19, 2018 at 21:27
If I buy a new STM32F303xC and solder it to my board, will it power up in DFU mode? Is it required to pull BOOT0 high to enter DFU mode? I would like to do first-time programming without manually using a jumper.
#new-unprogrammed-stm32f303xc-into-dfu-mode
Tesla DeLorean
Guru
April 19, 2018
Posted on April 20, 2018 at 00:30
Pretty sure the F3 will expect you to pull BOOT0 High to enter the System Loader
Or you could use SWD/JTAG if you've wired that up.
John Henry
Posted on April 20, 2018 at 15:56
I figured as such. I'll have to add a jumper or button. After application code is loaded I will have the ability to enter DFU from the program.
