brath
How to send a udp packet usig LwIP?
  • December 26, 2018
  • 5 replies
  • 1620 views
i want to send a udp packet usig lwip im new to stm can anyone help me out
Which device is using ?
You'll probably want to review LwIP examples as you can find available in the Cube firmware package dedicated for your board.
You can also, use the STM32CubeMx tool to generate initialization code. This allow you to choose the microcontroller, select the peripherals you want and map them to pins graphically.
Kind Regards,
Imen
brath
brathAuthor
thanku actually im working on stm32h743ZI i have used cubemx but getting error have a look at it
The "Undefined symbol" error means that your application does not include object, source or libraries including this function. You should review the configuration of your project, and the files included and make sure that your project contains all the required library source files.
Kind Regards,
Imen
brath
brathAuthor
Can you share the .IOC file so that I could make what's the mistake I have done​
